im confused... help me!!!!!
Old Nov 12, 2006 | 09:59 PM
BigDimo2624's Avatar
Default im confused... help me!!!!!
i dont know much about premixing 2 stroke engines. i dont have a ratio cup, so could you tell me if 50:1 uses more oil or less that 32:1. i rebuilt my buddies blasters top end and im running 50:1 with amsoil and premium gasoline. It is WAY to smokey. and i checked to see if its a bad seal, and fortunately that wasnt the problem. so i just need to know what ratio to use that will not make excessive smoke, and that willl not destroy my top end. please give me some answers ASAP i want to try and have it right tomororw!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 12, 2006 | 10:43 PM
rdeeno's Avatar
Someone correct me it I am wrong but I believe 50:1 is 50 parts gas to 1 part oil, so it has less oil in it. As far as the blaster is concern. I would call a yamaha place and ask what they recommend to run in it and what octane of fuel. If it doesn't have high compression then you are wasting money on fuel. With my chainsaw and weedeater, I use Stilh 2 stroke oil, that comes in little six packs. The little bottles will tell you how much gas to mix with, in my case 1 gallon. I just get a 1 gallon gas jug and put in one bottle. Can't get much easier.
Old Nov 12, 2006 | 10:54 PM
well the manual reccomends premium gasoline. before i rebuiilt the top end the top end was destroyed becasue of detonation. my teacher thinks it was because the previous owned shaved the cylinder head. and i dont think premium gasoline was used either, and thats supposed to help prevent detonation.
Old Nov 12, 2006 | 11:03 PM
Vulcan700's Avatar
50:1 is less oil for sure
50 parts gas to one part oil
Like 50 gal of fuel and 1 gal oil
3.125 gal and 8 oz of oil = a 50 to 1 mix
It is always better to run a little rich for the lubrication factor but it will foul plugs faster
Old Nov 12, 2006 | 11:11 PM
if its not my premix ratio, and its not burning my trans oil, what could be the reason why im getting excessive smoke and oil coming out before my exhaust (between cylinder and pipe)
Old Nov 12, 2006 | 11:15 PM
rdeeno's Avatar
If it recommends it, then use premium fuel. A problem I have seen with a 2 smoke is if you ride around or should I say cruising in it, it will foul plugs. Next thing someone puts a hotter plug in to help with the fouling which is ok till you start driving it hard, than it will melt down. Not saying that is what happen to this motor, but I have seen it happen before. 2 strokes make good power, but you got to keep them winded up. Also, I would use a 2 stroke oil yamaha or a dealer recommends. An make sure you have the recommended plug in it also. LOL
Old Nov 12, 2006 | 11:29 PM
Vulcan700's Avatar
All 2 strokes smoke at the start and they will all drip a little that is the nature of the beast. I hope you are not just putting around as that will kill the poor motor. The 2 strokes love to move the RPM need to be keep at a high rate to make power and run right. If the bike has warmed up and is at running temp it should not smoke a lot unless you let it idle for a short time then give it the gas it will smoke just for a few seconds and should clear up but it will always smoke some.
Old Nov 13, 2006 | 12:11 AM
so the worst the smoke could do is foul plugs, and **** off the neighbors? not bad. hahaha. what are the chances that my rings will stick?
Old Nov 13, 2006 | 12:25 AM
Vulcan700's Avatar
Well if it is smoking that will never happen just screw up the plug if you run to much oil through it Hope you know that 2 strokes like to be run look at the little tinny RC motors they are 2 strokes and run a 18 thousand rpm's and the race one are well over 20 thousand rpm's 2 strokes are made to run fast ask any of the banshee racers
rctoyguy
Jan 14, 2014 04:06 PM
jonzo22
Jan 5, 2011 11:21 PM
duster
Jun 12, 2008 08:17 AM
tsdgoes
Mar 30, 2007 02:02 PM
midlifecrisis
Nov 22, 2006 06:01 PM
