92 lt80 vent/vac hoses Which ones go where
Old Nov 23, 2006 | 11:34 AM
QIKER's Avatar
Default 92 lt80 vent/vac hoses Which ones go where
I got my sons quad going with a new stator but it appears that I am missing or misplaced some vac hoses and vents.Can anyone send me a diagrahm or schematic for there proper placement..Thanks in advance..The quad is hard to start and it wont run on petcock on position.There is no hose to connect.Where would this hose go into carb??
Old Nov 24, 2006 | 10:44 AM
LT80's Avatar
LT80 Expert
The vacumm hole is the one closest to the motor. The front one is the carb vent. Middle is the fuel supply.
Old Nov 24, 2006 | 08:41 PM
QIKER's Avatar
Thanks for the help.I found the vent hose and all is good now.I found that the gascap was bad and was not letting fuel into the bowl.I swapped it out with my lt250r cap and it fired up on first push.If the petcock is in prime position it will flow gas freely now.If it is on on position I think it works off of vac I will go riding with my kid tommorrow and see if the on position works.Again thanks for the help..You should change your user name to...LT80GURU........LOL
QuadRiders
Oct 22, 2015 04:13 PM
Sassinm1
Sep 30, 2015 04:23 AM
bigred20653
Sep 19, 2015 02:11 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
