Tri Z problem ?
Old Nov 27, 2006 | 01:14 AM
OzzyZrider's Avatar
Default Tri Z problem ?
G'day all. First time in the forum, its great to read all of the threads, and if you haven't guessed I own a Tri Z 250 (1985) down under in Australia. Just wanted some feedback on the following. I was riding on the weekend on the beach, temp was 35 C - which is about 95 F - and after about an hour started to get a surging problem while in top gear going at a decent pace. I had to end up stopping for about 20 minutes and after that resumed and all was ok. Has anyone had this happen to them ? Would it be that the bike was too hot ? Although the temp light (which works) didn't come on. Thanks.
Old Dec 26, 2006 | 07:39 PM
trizinNY's Avatar
sometimes the fuel pump cant keep up at a fast pace they were noted for this..any problems since? could possibly need to clean the carb and jets.you can also check for a air intake leak by starting it letting it idel and spray some carb cleaner around the intake boot for a cracked boot.
Old Jan 7, 2007 | 07:47 PM
OzzyZrider's Avatar
Thanks. No, no more problems to date but I will clean the carby and jets and see how I go.
Old Jan 11, 2007 | 09:10 AM
carlw's Avatar
go run it wide open doun the beach and pull the plug see what it looks like.
Old Jan 13, 2007 | 08:09 PM
Billy08's Avatar
Im not sure if u were going through any water, but i notice with my atc, when i gp through water and the engine gets wet, it seems to cut out on me, and i have to shut it off to let it dry a bit, then it works best kind.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
