Eton Stator Woes Continue...
Old Nov 30, 2006 | 10:59 AM
probablecause's Avatar
Default Eton Stator Woes Continue...
I bought a new stator off of ebay which was supposed to be a higher output one but when I installed it, no spark at all. Pulled it out and put in the old one and the bike fired right up. Put the new one in and no fire at all. Sent new one back and got the following response which I can hope someone can verify:
"I have received the stator assy. and I put it in the bench tester / ignition set-up we use to test parts of the system and it gave good fire. This is the first time that one has been used on a late model RXL, and I have really bad times with the Chinese on parts and literature on the ETON's. But I have found that they had two different type ignition systems for the RXL 90's, but I cannot find out the years. What I did find out from ETON america ( KEENEINDUSTRIES) is that they look identical, but with major differences.The OHM reading from the CDI source(large winding on stator)on one is 2.0- 4.0 ohms, and the other is 200-400 ohm's. Also one Black Pulse coil outside flywheel is 100-115 ohms, the other pulse is 200-450 ohms. My stators are the lower ratings. If you could measure your pulse coil and large windings ohm ratings, it would help clear this up."
Has anyone every heard of this because when I check the parts diagram, they only show one stator. I can't find any technical stuff on the ohms either.
Old Dec 2, 2006 | 02:14 AM
Fastestdad's Avatar
Seen a bunch of them and know theres a little difference on some with lights. If your old one works I'd get your money back and use it.
Old Oct 15, 2010 | 09:10 PM
GHOSTRDR71's Avatar
i'm having problems with a yxl150. i got redesigned stator for it and blows fuse after 2 hits of starter, with new cdi, but no spark with old cdi. Replaced all other electrical components no help. Any help would be greatly appriciated.
Old Oct 16, 2010 | 03:47 PM
LynnEdwards's Avatar
Electrical Expert
If you unplug the CDI does the fuse blowing stop? If your old CDI doesn't blow fuses, and the new CDI does, then this suggests your new CDI is bad, or it is not the right CDI.
Old Oct 17, 2010 | 01:48 AM
GHOSTRDR71's Avatar
yeah that was my thinking to but you got the no return on electrical roadblock. think il use this pos as target practice
Old Oct 18, 2010 | 05:14 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
Call Rickystator and end your woes. They know everything about all stators and will be glad to help.
Old Nov 13, 2010 | 07:47 PM
GHOSTRDR71's Avatar
ok thanks. wife wants to ride. i have yz125 sons have honda trx90 and rt100. she not happy thanks for the input.
Old Jun 21, 2015 | 05:39 AM
Carver Sloan's Avatar
It has been my limited experience the E-Ton stators are unique and the generic chinese stators will not work for an E-Ton.
ultangler
Nov 30, 2024 01:35 AM
salixair
Nov 3, 2015 08:25 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
Minimod
Sep 10, 2015 09:20 PM
