97 sportsman 500
Old Dec 16, 2006 | 12:17 AM
dan68rs's Avatar
Default 97 sportsman 500
I have a 97 sportsman 500, It will not rev up. It will some times but other times it will bog down.. I was wondering if there was a way to bypass the throttle sensor that causes it to kill the motor if the throttle sticks.. reason that I think it may be this is that when I got it the box on the throttle lever was broken and it idles allittle rough untill I put it in reverse, just like I fliped a switch the thing idles perfect. Also does anyone know what the float levels should be on the carb.. thanks
Old Dec 16, 2006 | 10:06 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i could be wrong, but i beleave its just a grounding out type switch w/ 2 wires. so if you unhook it it will do away w/the switch. some one correct me if i'm wrong( more then likely lol) as far as the float i dont have the book to go w/ so i just set it some what level across a generic setting but a good place to start.
Old Dec 19, 2006 | 09:05 PM
dan68rs's Avatar
Well thanks for the reply.. I found that the idle problem was in the throttle adjustment, so I got that fixed the idle problem. So from there I pulled the carb to re-check the float level and set it to about 11 mm, did not have anything other than my shop manual for my warrior, the carb looks close to the same.. but then I cranked it up and still would not rev up without bogging. then I noticed that the airbox was not sealing good, held it down and reved it up and it did just fine.. so the bogging problem was to much air.. I still need the float levels for this atv, I have a little stumble off idle.
Old Dec 23, 2006 | 01:00 AM
cocacolacowboy's Avatar
Hi...don't know if you still need the info, but here ya go....13 MM or .51 in.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
