2005 Rancher ES- Lights and Display popping fuse
Old Jan 6, 2007 | 10:22 AM
ATVMONKEY's Avatar
Default 2005 Rancher ES- Lights and Display popping fuse
I have a 2005 Rancher ES. The lights and display go out every so often. I check the 15a fuse and its blown. Does anyone have any suggestions for fixing this problem? Would putting a 20a fuse in there really be all that bad? Thanks for any and all help.
Old Jan 6, 2007 | 03:31 PM
RancherATCrazy's Avatar
Does it have a winch? You have a short somewhere that is causing the problem. A common spot is where the winch is spliced into the hot wire (usually around the display). I wouldn't recomend putting in a 20 AMP.
Old Jan 6, 2007 | 07:47 PM
ATVMONKEY's Avatar
no winch.
went by the honda house. the tech said it wouldnt hurt to try a 20amp. i tried it today and drove 15 miles with no problems and no fuse pop.
Old Jan 8, 2007 | 08:51 PM
LittleBill's Avatar
putting a higher rated fuse in something not designed for it is just stupid. fuses don't pop for no reason fix the short before you catch your electrical on fire
i can't believe people still even recommend this, why the hell you think they use that particular fuse?
Old Jan 9, 2007 | 08:55 PM
ATVMONKEY's Avatar
i took the quad in to the honda shop today to get the short fixed. im not going ot screw around with the higher amp fuse
Old Nov 7, 2020 | 10:59 AM
pbell's Avatar
Hey ATVMONKEY -
I have the same problem.
What did the dealer do to fix it?
Thanks.
txpedsrt1
Feb 3, 2017 08:07 PM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
jayking232003
Jul 23, 2015 05:48 PM
