660 r problems as usuall
Old Jan 26, 2007 | 07:33 PM
Raptor660R03's Avatar
Default 660 r problems as usuall
Hey guys i got a 03 660 and the starter is giving me probs. all it does is freewheel and it backfired before it died last time it was runnin and i dont know if it is the one way or bolts in the one way but i would like to see if any of you guys know so i can have an idea of what to do before i tear it down but any input is appreciated greatly and also which quad should i go for a 450r or a yfz 450 cause im do for a new quad anyways lol but let me know thanks
Old Jan 26, 2007 | 08:20 PM
caliraptor's Avatar
if it freewheels and your motor/tranny havent locked up then its probably the one-way. Broken bolts would make noise or maybe even lock up the tranny and a buster one way will just cause the started to freewheel. Only way to really know is to take off the cover. I wouldnt use the quad until its fixed...debris might be floating around and can cause more damage. Your looking at $200+ on parts to fix it (bearing, gear and gaskets). Good luck!
Old Jan 27, 2007 | 10:23 AM
Yea it was making a rattling noise in the side case would that be the broken bolts???
Old Jan 27, 2007 | 11:04 AM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
More than likely when it backfired you sheered the bolts off; that bolt the oneway to the flywheel.........
Easy fix.......find Raptor tranny . com and it will give you some insight on how and what's needed to fix it. Good Luck [img]i/expressions/face-icon-small-smile.gif[/img]
Nondem
Feb 22, 2020 12:20 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
toonces
Oct 19, 2015 02:21 AM
hondarider1234
Jul 21, 2015 11:53 PM
J-Mack
Jul 4, 2015 04:19 PM
