TrailBlazer 250 Starter
Old Apr 15, 2007 | 08:29 PM
Jaxson85's Avatar
Default TrailBlazer 250 Starter
My mom has a 2001 Polaris 250 TrailBlazer and it needs a new electric starter, I have the starter ready to come out except there is 1 bolt in betwean the motor and starter and I can't get to it. How do I? I have tried to pull off what I think is to be the clutch to be able to pull off the cover that is betwean the clutch and motor but I was unsuccessful. Does anyone have any tips for me? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 16, 2007 | 05:59 PM
cdrmotorsports's Avatar
You need to remove both clutches and the cover. You'll need a clutch puller for this. You can also try to tip the TB up on it's back wheels and remove the skid plate to get at it that way.
Old Apr 16, 2007 | 06:37 PM
trailblazermudrunner's Avatar
did u try to by pass the start thro the cylinoid???
Old Apr 18, 2007 | 12:10 AM
Jaxson85's Avatar
cdrmotorsports; where can i get a clutch puller? does auto-parts stores rent them out?
trailblazermudrunner; the cyliniod is ok as far as i know, the starter has a nice hole in it's case because she loaned the bike out to a friend and it came back with a hole in the starters case, don't know how it got there but i was just asked to see if i could fix it.
Old Apr 18, 2007 | 02:14 PM
I'm pretty sure you can rent a clutch puller from a place like Autozone. Do you hear a click when you press the start button? If so, the solenoid is OK. If there is no click, get a heavy wire and put it across the two big poles on the solenoid while hitting the start button.
Old Apr 18, 2007 | 08:40 PM
vig's Avatar
vig
Hey if you tip the machine up like in a wheelie,remove the skid plate and you can get to the bolts, it is tight but it can be done, and you dont have to remove the clutches.
Johnny Mac
Aug 15, 2019 03:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
