Sport Quads Discussions on sport quads.
dirt trails
Old Apr 16, 2007 | 09:37 PM
fatboysh's Avatar
Default dirt trails
i ride on dirt and gravel trails and sometimes mud...i was wondering what chain lube i should buy...i am new to owning a quad so i have alot of questions that are stupid to most of you...and where do i get it...thanks in advance...one more thing...what do i use to clean my k&n air filter
Old Apr 16, 2007 | 11:16 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default dirt trails
Your chain is permanently lubed at the factory. Each pivot is injected with grease, and the O-ring is there to hold the grease in. Therefore, you really don't need to lube the internals of your chain...only the outside where it interfaces with the sprockets, and you need to keep your O-rings supple, so they don't crack.
I use Maxima chain wax. It dries, so it doesn't attract dirt. Wet lubes will attract dirt, and become grinding paste and destroy your O-rings.
Old Apr 18, 2007 | 09:24 PM
kyledc18's Avatar
Default dirt trails
I think a good oil is Bel ray o ring safe oil.
Old Apr 19, 2007 | 02:12 AM
Doctorturbo's Avatar
GOT BOOST!
Default dirt trails
I agree with reconrangern on this. I forget the stats but something like 85% of chain wear is in the pin and roller. With an O ring chain your covered. If you lube your chain with sticky lubes it can sometimes cause more wear. Sand and volcanic soils will really wear your chain if they can stick to it.
Frisky2050
Apr 9, 2020 11:19 AM
Nondem
Feb 22, 2020 12:20 PM
RickyMac
Mar 5, 2016 07:27 AM
black_thunder
Aug 14, 2015 11:22 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
