300ex problem
Old Jun 5, 2007 | 12:57 AM
Matt1980's Avatar
Default 300ex problem
I just got a 1999 honda 300ex for 1150 dollars that is in incredible shape for the money and the only thing wrong with it is that it needed rear brake pads so we got new pads and took off the caliper and when we try to push the piston in it will not budge. So do you have any clue on what are problem is.
Old Jun 5, 2007 | 02:07 PM
hondabuster's Avatar
Did you back off the bolt on the far side for the parking brake adjustment?
Old Jun 5, 2007 | 07:05 PM
TommyA300's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Matt1980
I just got a 1999 honda 300ex for 1150 dollars that is in incredible shape for the money and the only thing wrong with it is that it needed rear brake pads so we got new pads and took off the caliper and when we try to push the piston in it will not budge. So do you have any clue on what are problem is.</end quote></div>
Beside making sure the parking brake is not engaged.
Mount the unit back on with the old plates snug the bolts hand tight or better.
Stretch a small hose over the bleeder into a clean jar Then crack loose the bleeder wedge a large screw driver between the plate and disk and give it a nudge, this will assure the piston is not cocked it will push back in evenly! Watch out not to get squirted in the face as you compress the piston back into the cylinder. The hose may pop off. If the break fluid is clean it can be reused back into the reservoir
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
