2006 Sportsman 500 HO - Clutch Problem
Old Jun 8, 2007 | 09:12 AM
Kgun7's Avatar
Default 2006 Sportsman 500 HO - Clutch Problem
2006 Sportsman 500 HO - I've been riding for about 6months now and i am experiencing gear shifting issues. The engine RPM's really shoot up (5-6k) before it will shift from 1st to 2nd gear. I had the drive and driven clutch replaced under warranty, but I'm still getting the same results.
If I vary the throttle it will finally kick into the next gear, and top speed and higher gears don't seem to be as bad. As it heats up the problem gets worse.
Any suggestions would be appreciated.
Thanks.
Old Jun 8, 2007 | 12:05 PM
sheepdogMSP8117's Avatar
Kgun,
Not sure I completely understand what you mean by shifting from 1st to 2nd, since the Sportsman is an Automatic. And you mention kick into the next gear and higher gears, I just don't know what you're trying to say.
Old Jun 8, 2007 | 12:33 PM
Kgun7's Avatar
You are correct ... it is automatic. By "kick in" I mean when the clutch attains the next gear it lurches forward pretty good. I don't know if the clutch can be adjusted, but that sounds like the problem.
Ltz250goon
Sport Quads
Dec 3, 2015 07:51 PM
Land_shark1
Jul 10, 2015 12:53 AM
BillinIll
Jun 19, 2015 01:39 PM
Joe Paul
May 27, 2015 09:04 AM
Dave8888
May 2, 2001 06:55 AM
