Solution for clogging rads.
Old Jun 13, 2007 | 10:03 PM
Cormacs's Avatar
Default Solution for clogging rads.
Here is just a quick simple solution I have created to keep my rad from clogging. I have had it out on two very muddy complicated rides and it stays cool now. All it took was about 10 feet of 3/4 inch rad hose a $20 roof vent from home depot and about an afternoons worth of work.
Click Here
Old Jun 13, 2007 | 10:11 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Good job..............No room for refreshments though!!!!!!!!!!!!...........Caper.......
Where is the fan?????
Old Jun 14, 2007 | 12:08 AM
Cormacs's Avatar
The fan fits nicely underneath the rad exactly how it is mounted stock. I cut a large hole in the bottom of the compartment to allow for the fan and a place for the air to escape. In fact now with the rad there during the cold winter runs I can keep a nice hot can of soup. lol
Old Jun 14, 2007 | 12:42 AM
SCRAMMYTODD's Avatar
Very good idea, but I like my cooler in the front to be COOL LOL and I built a trailside pressure washer so could play in the mud and not worry.
CORMACS Where are you from? I saw one of your pics was from Mattawa
Old Jun 14, 2007 | 07:07 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
scrammy, hows that t.washer working for ya?havent had time to even ride let alone use mine.[img]i/expressions/face-icon-small-mad.gif[/img]
Old Jun 14, 2007 | 08:02 AM
Cormacs's Avatar
I'm from Ottawa, but I generally ride up in Johnstown. I built a trailwasher myself. A very good trail washer with two RV style water pumps that has tons of pressure. It blasts through the rad no problem. But the riding I do I can't be stopping every 20 minutes to clean it out. We usually dunk into a very deep very thick mudhole every 15 minutes and spend upwards of 10 minutes in each hole. Not only that I find because the trail washer just can't get certain areas, like the corners and the center where the rad fan sits it doesn't take long for it to start overheating. I still have my back compatment for a cooler. I find there is no good way to clean your rad other then to take it right out and clean each row individually. I've tried alot of ideas but I just gave up and decided to make something that will solve the idea not bandaid it.
Old Jun 14, 2007 | 12:05 PM
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
scrammy, hows that t.washer working for ya?havent had time to even ride let alone use mine.[img][/img]</end quote></div>
I tried it in the shop one time LOL I hit the 800 mile mark about 3 weeks ago and I haven't been out since. It's almost too hot anyways LOL
Old Jun 14, 2007 | 06:09 PM
RticKwad's Avatar
Runs Stealth!
Cormac,
I seen the same from Cordachine, do you guys know each other?
Yea that is cool! (No pun intended), LOL. I may consider doing thing
design too.. Any performance issues with how its mounted (side-ways and
several inches higher)?
Regards,
R'
Old Jun 14, 2007 | 07:07 PM
Cormacs's Avatar
no it doesn't affect performance at all. The only reason rads are mounted verticle is for air flow. But since there is a scoop that funnels the air and shoots it down, it being horizontal has no affect.
dannytas
Sep 26, 2017 06:31 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Ask the Editor
Sep 14, 2015 08:57 AM
scorpiankill
Sep 10, 2015 09:14 PM
Brandon400
Sep 5, 2015 08:44 PM
