Stripped Bellcrank
Old Jun 18, 2007 | 11:49 PM
OC2Az's Avatar
Default Stripped Bellcrank
My 2007 Trail Boss 330 has a stripped bellcrank and shift shaff. Does anyone know if this is an easy fix? The bellcrank looks easy enough but I'm not sure about the shaft. Also, since I've only had this for three months, should it be covered under warranty? It doesn't appear to be stripped internally because I can change the gears (F-N-R) with a wrench.
Old Jun 19, 2007 | 12:19 AM
Williebee's Avatar
If i were you i'd get off the stsck, and take it in the daeler and have it checked out ; the longer you wait the more time they can say has passed and it's out of warrannty ! I would take it in like yesterday !!!! lol williebee
Old Jun 19, 2007 | 07:59 AM
ftwflh's Avatar
You dont strip the shaft.It is steel what you do is strip the bellcranck splines.
Old Jun 19, 2007 | 11:53 PM
Williebee's Avatar
Well whatever the case is, my point is i would take it into a dealer and have it checked out ; before it is out of warantee ! ....williebe
Old Jan 6, 2008 | 10:53 PM
Cmitchell79's Avatar
Does anyone know what is involved in changing the shift shaft if it is stripped? Can you replace it without splitting the cases?
Old Jan 6, 2008 | 10:56 PM
ftwflh's Avatar
you have to pull the tranny and split the cases to replace the shift shaft
Old Jan 6, 2008 | 11:47 PM
OC2Az's Avatar
My problem was a stripped bellcrank. The shift shaft was fine. Quick, easy, cheap fix.
tysonbully
Sep 28, 2015 02:30 AM
ny250r
Apr 27, 2001 06:11 PM
Bayou3004x4
Mar 22, 2001 03:20 AM
brokemybanshee
23
Jan 6, 2001 12:37 AM
