Rancher - waterproofing advice
Old Jun 28, 2007 | 05:20 PM
FormulaLT1's Avatar
Default Rancher - waterproofing advice
Hello,
I have a friend who has an 02 Honda Rancher 4x4. He's had the thing rebuilt twice, and the mechanic has told him the problem was operating in too deep of water. Now we're curious how he could waterproof it. So my questions are:
Where is the air intake located?
What is the best way to waterproof it (let's not go overboard, just make it able to handle water up do the handlebars safely)?
Any other advice?
Thanks!
Old Jun 28, 2007 | 09:00 PM
mykool61679's Avatar
the intake is uder the steering pod. you need to snorkle the intake, extend the differential lines, brake lines and plug the carb vent line.( only when in water.) di-electric grease on all electrical connections.
Old Jun 29, 2007 | 01:00 AM
Gimpster's Avatar
Remove the seaat
Look at the airbox, there is a white tube exiting it.
Follow it foreward and you will see where it ends just foreward of where the front edge of the seat rests, just on the upper backside of the fuel tank under the plastic is the opening for the air intake. Also take note of the rubber hoses in that area. There are 2 hoses that are diffferential breathers and one that leads to the carb breather. Laso look on the bottom of the carb. There should be a hose attatched to the bowl. It runs down under the quad. There should be a one way valve along the way. If not put one in to keep water from getting into the float overflow. The other hoses I mentioned need to be extended to the handle bar ares and the white tube modified in some way to extend above the water level that will be riden in. An automotive spray ignition sealer should be used over and around all electrical connections. Be careful of grease in the electrical fittings. It may rot the factory rubber seal in time.
----- Gimpster -----
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Johnny Mac
Aug 15, 2019 03:13 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Clint Russell
Sep 25, 2015 03:20 PM
