350L no go
Old Jul 18, 2007 | 08:38 PM
spacecub's Avatar
Default 350L no go
I have recently gotten a 93 350L 4x4 and it ran great the other day i went to move it and it started good ran it a few minutes to warm it up and went into the backyard and it quit wouldnt start again the next day it started after much effort and ran a little while then bogged out now i just get a sputter once in a while need help!!!!!!
Old Jul 18, 2007 | 11:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default 350L no go
check the plug from being fouled/flooded and carb for being dirty if it has good fire and getting gas.
Old Jul 18, 2007 | 11:55 PM
textrout's Avatar
Default 350L no go
He is right, most likely spark plug (always, always carry at least one spare) bc they go so quickly, or dirty carb. I had a 93 305L as one of my first atv's. I sure learned how to change out those carb kits. I put 2000 big ones into that bike, including an overhaul, etc... before it dawned on me that it woult never be as reliable as I wanted and needed it to be. For a while, it was just a challenge, later just a hassle. It sure had the torgue though!!! For the first 50 yards, I could outrun a lot of bikes on it. You could fix it over and over, but my advice is to put it out of it's misery. A 45 long colt between the eyes will make it feel much better. Then get a late model sportsman. You'll be glad you did.
Either way, good luck! Carb kits are pretty cheap.
Old Jul 19, 2007 | 12:21 AM
ftwflh's Avatar
Default 350L no go
Do a compresion check with it cold and then hot I bet it is below 100psi
Old Jul 19, 2007 | 12:22 AM
ftwflh's Avatar
Default 350L no go
cornermike
Aug 10, 2016 06:47 AM
338 lap mag
Technical and How-To Articles
Aug 2, 2015 03:57 AM
cornermike
Jul 30, 2015 06:37 AM
cornermike
Jun 3, 2015 07:27 AM
