86 fourtrax timing?? problem
Old Jul 24, 2007 | 08:10 PM
smbthunderbay's Avatar
Default 86 fourtrax timing?? problem
new to this board and looking for a little help. have an 86 honda fourtrax 350 4x4.
engine was stripped and rebuilt this winter. put together and it run like a dream for about 200 miles. i was riding it on the weekend, it was running great untill it felt like the carb was on full. it stalled itself out and will not restart. getting fuel and air. good spark. checked cam timing and it is was out so i adjusted it and it seems to keep going out of time. replaced the chain tensioner but that does not help. any ideas?? thanks in advance
Old Jul 24, 2007 | 09:04 PM
HondaMechanic's Avatar
Did you replace the cam chain also ..?
Old Jul 24, 2007 | 10:26 PM
no the chain was not replaced. do you know if there is a master link in those chains??
Old Jul 24, 2007 | 11:08 PM
No they are an endless chain ... It didn't jump enough for the valves to touch the piston did it .. Did you check the valve clearances , if a valve/s are bent there will be more than 0.08 mm (0.003 in) valve clearance ..
Old Jul 25, 2007 | 05:52 PM
where are you measuring the valve clearance??
Old Jul 25, 2007 | 09:08 PM
What is your email address and I will email you the maintenance section from the 1986-93 TRX350D PDF shop manual .. It will explane valve adjustment ..
Old Jul 25, 2007 | 09:26 PM
smbthunderbay@yahoo.ca
thanks
Old Apr 4, 2023 | 07:09 PM
mathew4058's Avatar
Do you still have the manuals?
Wooodyii2
Nov 16, 2020 07:14 PM
garyt1975
Jun 5, 2015 08:53 AM
blaze_master
May 26, 2015 11:18 AM
CanadianViking
Feb 16, 2001 11:56 AM
MrElussive
Nov 10, 2000 05:05 PM
