2005 kodiak 450 brake problem
Old Jul 27, 2007 | 07:35 PM
snoopyddog's Avatar
Default 2005 kodiak 450 brake problem
Anyone having problems with their kodiak 450 rear brakes. I am eating them up like crazy.
I brought the bike to a dealership, and had them " profesionally adjusted and bled", but I am still going through a set of rear pads within 350 ish miles ( 600 kms). they say it's the mud, getting in between the pads and rotor ( that's why I went with disk brakes, to avoid this problem with drums )
I also had the caliper looked at by a local mechanic, and it seems to be in good working order
2005 kodiak 450 ....2460 kms ( 1200 miles ish ) going on 5th set of pads
any advice would be greatly appreciated
cheers
Old Jul 28, 2007 | 12:40 AM
wildwest1011's Avatar
stop using the breaks so damn much! lol
j/k
I've only changed the front pads on my bruin 1x so far (I know , I don't ride enough) but the mechanic that helped me do it (saved me $$$ from the stealer) told me I need to clean them out more then I do/did.
The backer plates were even gone...the calipers were over extended (piston) but they went back in, luckily.
I haven't really got to ride since they were fixed..either your braking too much, you need to rinse them out after each ride or..what pads are you using, maybe you should look into a more expensive aftermarket brand is more durable?
could be any/all or a combo of the above, who knows. maybe somebody does.
I've seen a few posts about breaks going out too soon on the kodiak, and everyone shared the love for mud..like I do, so I'm going to try to actually wash my quad once in a while and hope that is all it is.
Good luck!
Old Jul 28, 2007 | 01:47 AM
BrianE's Avatar
I agree . Use more engine breaking in combination with front brakes. I only use rear brakes if I need to stop fast. Also try after market brake pads.
Old Jul 28, 2007 | 10:20 AM
snoopyddog's Avatar
thanks for the advice.
Old Jul 28, 2007 | 01:19 PM
07Wolvey450's Avatar
i barely ever use the rear brakes on my wolverine 450. i can stop fast enough with engine braking and the front brakes, and the rear brakes on the wolvey are kind of spongey and not the greatest. i would assume the kodiak is different because it has irs, right?
Old Jul 28, 2007 | 09:30 PM
snoopyddog's Avatar
if by IRS you mean independant rear suspension, then yes it does, but the brakes are also spongy on the kodiak . It could very well be a usage problem, in other words, a operator error, but hummm I just don't know.
Old Jul 29, 2007 | 03:54 PM
i dont think it could be that much of an operator error, iv still got plenty of pad left on my rear brake at 700 mi. does each rear wheel have a disc brake?. i would think that would help with the rear brake spongeyness as opposed to only one on the straight axle of the wolv. try going with some aftermarket longer wear pads and stop using them so much. its not like a manual where u can ride all day with only engine braking and no brakes. just try to use the fronts more i guess.
Old Jul 29, 2007 | 08:17 PM
snoopyddog's Avatar
thanks,
it's a single disk on the rear and two disks on front, I'll go for the more expensive pads and start using the front more.. , and washing the bike too [img]i/expressions/face-icon-small-smile.gif[/img], yeah ok, so i like the mud too
cheers
Old Jul 29, 2007 | 09:20 PM
haha alright. i thought that it would have 2 disks on the rear, but whatever. you definietly gotta start washing it more to keep the mud out. good luck
Old Jul 29, 2007 | 09:49 PM
CraZySteve's Avatar
Yamaha needs to move that disk inboard, meaninig right next to the differential.. or heck.. even put it on the Rear driveshaft. I would try Moose XCR rear pads.. they work great on the dirtbikes I have owned in the past!
Jmuddin284
Jan 19, 2026 07:16 AM
Sjrpp
Nov 15, 2019 09:59 PM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jun 2, 2019 07:25 AM
Shifts
Jul 3, 2015 07:59 AM
