sceambler 500 clutch?
Old Sep 10, 2007 | 05:29 PM
auto2tech1999's Avatar
Default sceambler 500 clutch?
lookin for a better clutch setup.anyone have a good one
Old Sep 10, 2007 | 08:27 PM
SCRAMMYTODD's Avatar
Do a search on the forums and you will be overwhelmed with info
Old Sep 10, 2007 | 08:40 PM
ftwflh's Avatar
cheap way is a Dalton black/white primy spring and set your secondary to 2-2.Wakes up a stock 500 for around $30
ftwflh's Avatar
Old Sep 11, 2007 | 01:03 PM
sorry i hate to bother you but can you tell me hows thats done
Old Sep 11, 2007 | 06:18 PM
ftwflh's Avatar
It really helps to get a service manual when taking clutches apart for the first few times.But you can call Rick Ritter(618-644-3211) and get you the primary spring and it is a basic taske bolts out change spring put bolts in.The secondary gets tricky and you will need a second pair of hands to preload the spring.
Old Sep 11, 2007 | 06:34 PM
Cammer's Avatar
Hey,
I just put the Dalton black/white on my wifes 06 Scrammy 500. I am not sure if I like it. Not much difference in performance but big decrease in gas mileage. All the spring seems to have done is make it rev higher to engage and run at higher RPM therefore using more gas. The throttle response is still sluggish. I am not sure what effect the 2/2 setting would have.
Old Sep 11, 2007 | 06:43 PM
ftwflh's Avatar
The 2-2 setting will make some difference in take off and top rpms.But what you said about a spring change is exactly what it is supposed to do.Raise stall speed and give you more rpms.500 Scramblers use lots of gas anyway and with less than 4gals it seems to be low all the time.
Old Sep 11, 2007 | 06:50 PM
Cammer's Avatar
So how can you improve the throttle response? I have ridden the Outlander and KFX 700 and they seemed to be instant power compared to the Scrammy.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
