SUZUKI LT80
Old Oct 18, 2007 | 04:36 PM
TLAWYER's Avatar
Default SUZUKI LT80
I have a suzuki lt80 that set for a long time and the gas crystallized. I have cleaned out the carb several times and got it running, but it is slow to take off and hesitates badly. Once it is up to speed it runs fine. Any suggestions?
Old Oct 18, 2007 | 04:46 PM
AIRMOBILE101's Avatar
Default SUZUKI LT80
Clean the fuel lines?
Old Oct 18, 2007 | 05:04 PM
TLAWYER's Avatar
Default SUZUKI LT80
I changed them out for new. Any other suggestions? Would a new carb be necessary?
Old Oct 18, 2007 | 07:25 PM
Default SUZUKI LT80
No, as long as you cleaned it out. You have to make sure you cleaned everthing that the gas touches. Fuel tank, peacock(if equipped) , main jet, etc.
Old Oct 19, 2007 | 10:51 AM
LT80's Avatar
LT80 Expert
Default SUZUKI LT80
Maybe. Carbs do go bad from said gunk in it.
I agree w/101, remove both jets and clean thoroughly.remove the needle seat also and clean.
Try the petcock on prime to see if the fuel flow is a problem.
New plug? Pipe plugged?
Old Dec 31, 2007 | 11:08 PM
bushaurora's Avatar
Default SUZUKI LT80
It sounds to me like the machine is not getting enough air. If you have taken the carb off, then I am sure you know where the air filter is. If you are still running the stock filter, throw it away and put a new " UNI Filter on the machine. This will allow the machine the breath much, much better. And while you have the filter off, go ahead and take the carb back off and clean it once again and put the next biggest fuel jet in the carb. You can get the jet at your local Suzuki dealer. The same place you will need to get the new air filter from. Good Luck.
Old Dec 31, 2007 | 11:23 PM
skidooracer04's Avatar
Default SUZUKI LT80
get a ltr 250 [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 1, 2008 | 12:47 PM
LT80's Avatar
LT80 Expert
Default SUZUKI LT80
**yawn**
Old Jan 1, 2008 | 02:16 PM
onebigzj's Avatar
Default SUZUKI LT80
<div class="FTQUOTE"><begin quote>Originally posted by: skidooracer04
get a ltr 250 [IMG][/IMG]</end quote></div>
this comming from a kid with a 80 rapter and a 380 skidoo and a go cart ( 5 horse briggs motor I guess).
as for the lt 80. check the petcock. and replace the inline filter
VABrute
Jan 6, 2016 07:39 PM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Sep 1, 2015 11:59 PM
