Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
yamaha bear back fireing
Old Oct 24, 2007 | 09:48 PM
4wlmech's Avatar
Default yamaha bear back fireing
99 bear back fire thru carb how do i set timeing or ck coil volts,is there way to adj. idol very low then bk fires thu carb and dies
Old Oct 24, 2007 | 10:35 PM
hondabuster's Avatar
Its most likely a carb issue. Backfire is a sign of lean. Posibly the intake valve is a bit tighter than it should be, and that wont let the intake valve close completely. Start by Checking the clearance on the valves, and clean the carb, especially the pilot jet.
There should be a screw, on the carb,near the thottle cable, for adjusting the idle.
buckshit
Sep 24, 2015 08:49 PM
traumajunkie
Jun 15, 2015 10:10 AM
traumajunkie
Jun 14, 2015 01:55 PM
Steven Bandemer
May 27, 2015 07:39 PM
bgarre
Jan 23, 2000 10:17 PM
