500efi squeal
Old Nov 14, 2007 | 07:46 AM
wayout's Avatar
Default 500efi squeal
i just bought a 2008 500 efi,and when i go down a hill in high with adc turned on,i hear a loud sqealing noise comming from the front of the atv,anybody having this problem,,,,,,,,,,
Old Nov 14, 2007 | 08:34 AM
JAMIEZ71's Avatar
My guess it's the belt as it first catches. When it does that what happens when you touch the gas? Does it stop?
Old Nov 14, 2007 | 02:30 PM
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: wayout
i just bought a 2008 500 efi,and when i go down a hill in high with adc turned on,i hear a loud sqealing noise comming from the front of the atv,anybody having this problem,,,,,,,,,,</end quote></div>
If you read the owners manual you should be in low range when traveling slow with ADC engaged! You are slipping the belt!
Old Nov 14, 2007 | 07:17 PM
wayout's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: JAMIEZ71
My guess it's the belt as it first catches. When it does that what happens when you touch the gas? Does it stop?</end quote></div>
yes,and also it creeps in low gear every now and again,thanks
Old Nov 14, 2007 | 07:23 PM
wayout's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: RickCJ7
If you read the owners manual you should be in low range when traveling slow with ADC engaged! You are slipping the belt!</end quote></div>
thats what it sounds like,with the creeping in low gear,i thank you're right,i can't find any thing about having to be in low gear,that doesn't make sense,thats really stupid isn't it................thanks.........
Old Nov 16, 2007 | 07:00 AM
wayout's Avatar
what page is this at,i can't find anything .
Old Nov 16, 2007 | 07:21 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
high will squeel a little in high range w/ the adc on in high but not low. it is slipping the belt a little in high so low is the ticket to fixing it.
SwampCat
Sep 28, 2003 09:29 PM
Enigma
May 25, 2003 11:17 PM
newfieboy58
Feb 3, 2003 08:42 PM
newfieboy58
Nov 27, 2002 10:22 PM
vtCatamount
Jun 3, 2000 05:06 PM
