2005 Honda Rincon fuel gauge flashes
Old Dec 3, 2007 | 07:27 PM
rincon2005's Avatar
Default 2005 Honda Rincon fuel gauge flashes
Hi everyone I'm new here in the forum and I have a question.I own a 2005 Honda Rincon 650 GPScape.I recently had the dash replaced at my local Honda shop because the GPS wasn't working.Now my fuel gauge is flashing all the time even when my tank is full.Does anyone know what would be making my fuel gauge blink all the time?Thanks for any info
Old Dec 3, 2007 | 08:45 PM
HondaMechanic's Avatar
Is the fuel gage coupler connected ..?.. They flash if the coupler isn't connected ..
Old Dec 3, 2007 | 08:51 PM
rincon2005's Avatar
where abouts is the coupler located at.Thanks
Old Dec 4, 2007 | 02:27 PM
JeffinTD's Avatar
I believe on that year it has a 2 pin connector that is under the steering stem cover...
Old Dec 4, 2007 | 02:31 PM
rincon2005's Avatar
I have found that connector but it its plugged in.I tried unplugging it and hooking it back up but it doesn't change anything.
Old Dec 4, 2007 | 03:20 PM
JeffinTD's Avatar
If the thing is under warranty, I'd take it back to the shop.
If not, the service manual says that with the plug unplugged, all segments should blink, and with a wire jumped between both pins on the meter side of the plug, all segments should blink... If not, bad meter.
Then it says to remove the sending unit, and see if the meter reads full when the float is lifted, and empty when it is allowed to hang down.
Sensor should be 5-7 ohms in the full position, and 204 to 210 ohms at empty position.
Anyway, if it is still under warranty I'd say it is SEP (someone else's problem) to fix... Good luck.
Nondem
Feb 22, 2020 12:20 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
tporath
Jul 11, 2015 12:31 PM
Mikea1978
Jul 4, 2015 12:37 PM
Shifts
Jul 3, 2015 07:59 AM
