2005 Honda Rincon
Old Dec 3, 2007 | 07:36 PM
rincon2005's Avatar
Default 2005 Honda Rincon
I have an oil question.Can I use synthetic oil in my 650 Rincon without hurting anything.If so should I keep using 10w40 or can another grade be used.Thanks for any info
Old Dec 4, 2007 | 02:34 PM
JeffinTD's Avatar
There are a variety of weights that can be used depending on the temps. I believe synthetic without moly can be used. I personally use non-synthetic, however, and tend to change it at fairly low mile intervals.
When you change the filter, watch for the metal washer on the spring side of the filter element. They are known to stick to the filter, and it would be easy to throw it away with the old filter.
Don't forget to adjust the valves, and check the lock nuts on the tie rod ends (one of mine came loose on the 1st real ride).
Nondem
Feb 22, 2020 12:20 PM
txpedsrt1
Feb 3, 2017 08:07 PM
sportsman2005
Technical and How-To Articles
Aug 19, 2015 10:52 AM
colt1126
Aug 18, 2015 10:38 PM
tporath
Jul 11, 2015 12:31 PM
