Help somebody nobody ever seems to reply help pleas
Old Dec 12, 2007 | 08:47 PM
joshjines's Avatar
Default Help somebody nobody ever seems to reply help pleas
got my cr80r blew the piston replaced it with the one out of my ds80 which is a .5mm cr80r .7mm will it work and if the piston is at top dead center you cant see the rings right and when it is at bottom dead center you can see them perfect and there is a very small port uncoverd right
thanks for those who help
Old Dec 12, 2007 | 09:32 PM
mykool61679's Avatar
dont think so. you would be better off going a little big and bore the cylinder.
Old Dec 12, 2007 | 09:44 PM
khaney01's Avatar
Where are you getting the .5 and .7 mm measurements? It really isn't clear what you are asking other than if it will work, could be part of the problem with lack of responses.
To find out if it will work you need to get measurements of several things on the piston.
#1--diameter of piston....is the piston the right size for your cylinder with rings installed. Find out if your cylinder has been bored and what size piston that bore takes.
#2--location of the wrist pin....You need to measure the piston that was removed from the wrist pin hole to the top of the piston. If it is closer to the top of the piston it will lower the compression and not run very well. If it is closer to the bottom than the piston you removed it will (at bare minimum) raise compression and possibly cause detonation, or worst case scenario, smack the piston against the head causing damage to most every part of your engine.
#3--length of piston skirt....This is the area below the wrist pin and is important to keep the piston from rocking back and forth (piston slap) as it travels up and down the cylinder. Different engine combinations require different skirt lengths to keep this in check.
There are other factors to consider but these three will let you know really quickly if the piston will work while still being easy to measure. If any of the three are different the piston wont work. If they are the same post again on here and I'll let you know what else to check.
Kev
Old Dec 12, 2007 | 10:04 PM
joshjines's Avatar
HEY THINKS FOR THE GREAT INFO GUYS ALRIGHT I LOOKED BOTH OF THE BIKES UP AND THEY ARE BOTH 79CC 1 THE NEW PISTON IS LIKE A HAIR OR 2 TALLER THE WRIST PIN IS IN THE SAME SPOT BUT THE PISTON IS A HAIR OR 2 BIGGER EVERY THING CHECKS OUT THE SAME BUT THE NEW PISTON IS A HAIR OR 2 BIGGER
Old Dec 13, 2007 | 11:34 AM
khaney01's Avatar
You can reach 79cc in different ways. You can have a small bore and long stroke, short stroke and large bore, or you can have various combos in between that make 79cc.
If the piston is taller than the original, I wouldn't use it. It will raise your compression (at least) or hit the head. It will probably shroud the intake and exhaust ports as well. Sounds like you need to spring for the correct piston.
Kev
Old Dec 13, 2007 | 05:42 PM
joshjines's Avatar
thanks i have ordered a brand new wesico piston it is cheap for a piston $55
Old Dec 14, 2007 | 11:22 AM
khaney01's Avatar
Money well spent.
Old Dec 16, 2007 | 09:06 PM
joshjines's Avatar
Cheat Codes
Enter these during gameplay without pausing:
Cheat Effect
SQUARE, L2, R1, TRIANGLE, UP, SQUARE, L2, UP, X Never become hungry
X X Down R2 L2 O R1 O Square Peds become asian dudes with Katana's. Mostly black cars and motorcycles patrol the streets.
Square, R2, Down, Down, Left, Down, Left, Left, L2, X Cars Float Away When Hit
Right, L2, L2, Down, L2, Up, Up, L2, R2 Prostitutes pay you instead of you paying them
Circle, Right, Circle, Right, Left, Square, X Down Gives you an automatic six star wanted level
SQUARE, RIGHT, SQUARE, SQUARE, L2, X, TRIANGLE, X, TRIANGLE Attracts Prostitutes with Sex Toys/Gimp Suit
Down, R2, Down, R1, L2, Left, R1, L1, Left, Right Unlock Romero
Circle, R1, Circle, R1, Left, Left, R1, L1, Circle, Right Unlock Trashmaster
L2, Up, R1, R1, Left, R1, R1, R2, Right, Down No citizens or cops, only gang members having gun fights
L1 L1 R1 R1 L2 L1 R2 Down Left Up Turns All Vehicles Into Country Vehicles
R1, R2, L1, R2, Left, Down, Right, Up, Left, Down, Right, Up Weapons 1
R1, R2, L1, R2, Left, Down, Right, Up, Left, Down, Down, Left Weapons 2
R1, R1, Circle, R2, Up, Down, Up, Down, Up, Down Lower Wanted Level
R1, R1, Circle, R2, Right, Left, Right, Left, Right, Left Raise Wanted Level
R1, R2, L1 , X, Left , Down, Right, Up, Left, Down, Right, Up $250,000, full health and armor (also repairs cars if you are in one)
R1, R2, L1, R2, Left, Down, Right, Up, Left , Down, Down, Down Weapons 3
R2, R1, X, Triangle, X, Triangle, Up, Down Pedestrians have weapons
Down, Left, Up, Left, X, R2, R1, L2, L1 Pedestrian Riot (cannot be turned off)
Down, Up, Up, Up, X, R2, R1, L2, L2 Pedestrian Attack (cannot be turned off)
Circle, Circle, L1, Circle, Circle, Circle, L1, L2, R1, Triangle, Circle, Triangle Spawn A Rhino
Circle, L2, Up, R1, Left, X, R1, L1, Left, Circle Black Traffic
Up, Right, Right, L1, Right, Up, Square, L2 Spawn Rancher
Triangle, Up, Right, Down, L2, L1, Square Faster Gameplay
R2, L2, R1, L1, L2, R2, Square, Triangle, Circle, Triangle, L2, L1 Destroy Cars
Right, R2, Circle, R1, L2, Square, R1, R2 Cars on Water
Circle, Circle, L1, Square, L1, Square, Square, Square, L1, Triangle, O, Triangle Faster Clock
R2, X, L1, L1, L2, L2, L2, Square Overcast
R2, Circle, R1, L2, Left R1, L1, R2, L2 Aggressive Traffic
Triangle, Up, Right, Down, Square, R2, R1 Slower Gameplay
R2, Up, L2, Left, Left, R1, L1, Circle, Right Spawn a Stretch
Down, R1, Circle, L2, L2, X, R1, L1, Left, Left Spawn Bloodring Banger
Circle, L1, Up, R1, L2, X, R1, L1, Circle, X Spawn Caddy
Right, R1, Up, L2, L2, Left, R1, L1, R1, R1 Spawn Faster Cars
Circle, L1, Down, L2, Left, X, R1, L1, Right, Circle Pink Traffic
Right, L2, Down, R1, Left, Left, R1, L1, L2, L1 Commit Suicide
R2, Circle, Up, L1, Right, R1, Right, Up, Square, Triangle Flying Boats
Triangle, R1, R1, Left, R1, L1, R2, L1 Insane Handling
Triangle, L1, Triangle, R2, Square, L1, L1 All Vehicles Invisible (Except Motorcycles)
Right, R1, Up, L2, L2, Left, R1, L1, R1, R1 All Traffic Lights Stay Green
R2, L1, Circle, Right, L1, R1, Right, Up, circle, R2 Spawn Hotring Racer #2
R1, circle, R2, Right, L1, L2, X (2), Square, R1 Spawn Hotring Racer #1
R2, X, L1, L1, L2, L2, L2, Square Morning
R2, X, L1, L1, L2, L2, L2, Circle Storm
R2, X, L1, L1, L2, L2, L2, Triangle Night
R2, X, L1, L1, L2, L2, L2, X Fog
R2, X, L1, L1, L2, L2, L2, Down Noon
CIRCLE, RIGHT, CIRCLE, RIGHT, LEFT, SQUARE, TRIANGLE, UP Locks wanted level at however many stars you have. They will NEVER increase or decrease, not even with bribes/cheats. Still get attacked in impound.
Triangle, Up ,Up, Left, Right, Square, Circle, Down Max Fat
Triangle, Up ,Up, Left, Right, Square, Circle, Right Skinny
Left, Right, L1, L2, R1, R2, Up, Down, Left, Right Jetpack
Up, Up, Triangle, Triangle, Up, Up, Left, Right, Square, R2, R2 Jump 10 times higher
Left, Left, Down, Down, Up, Up, Square, Circle, Triangle, R1, R2 Spawns Quadbike
Triangle, Triangle, Square, Circle, X, L1, L1, Down, Up Spawns Hydra
Triangle, Triangle, Square, Circle, X, L1, L2, Down, Down Spawns Vortex
L1, L2, L2, Up, Down, Down, Up, R1, R2, R2 Any vehicle you punch this in, can blow up anything like a tank.
Triangle, Square, Circle, Circle, Square, Circle, Circle, L1, L2, L2, R1, R2. Jump 100 feet in air on bike
Up, Up, Down, Down, Square, Circle, L1, R1, Triangle, Down. Everyone bikini babes, all cars beach cars, Cj in shorts and flipflops.
Right, Up, R1, R1, R1, Down, Triangle, Triangle, X, Circle, L1, L1 Spawn a Monster
Left, Right, L1, L2, R1, R2, R2, Up, Down, Right, L1 spawn a parachute
Circle, Up, L1, L2, Down, R1, L1, L1, Left, Left, X, Triangle. Stuntplane
triangle,up,up,left,right,square,circle,left Max Muscle
SQUARE, L1, R1, RIGHT, X, UP, L1, LEFT, LEFT always midnight (time stuck at 00:00)
Up, Left, X, Triangle, R1, Circle, Circle, Circle, L2 Super Punch
up, L1, R1, up, right, up, x, L2, x, L1 Increase car speed
up, up, square, L2, right, x, R1, down, R2, circle Full Weapon Aiming Whilst Driving
square, down, L2, up, L1, circle, up, x, left Cars Fly
DOWN, SQUARE, UP, R2, R2, UP, RIGHT, RIGHT, UP Recruit Anyone (9mm)
Down, Left, L1, Down, Down, R2, Down, L2, Down Infinite Lung Capacity
Left, Left, L2, R1, Right, Square, Square, L1, L2, X Orange Sky
R2, L1, L1, RIGHT, RIGHT, UP, UP, X, L1, LEFT spawn dozer
Up, Down, L1, L1, L2, L2, L1, L2, R1, R2 Sand Storm
X, Down, Up, R2, Down, Triangle, L1, Triangle, Left No Peds, Hardly any traffic, Parked cars still spawn
Triangle, Triangle, L1, Square, Square, Circle, Square, Down, Circle Civilians are fast food workers & clowns, CJ is a clown, cars are pizza scooter, BF Injection, HotKnife, Tug, Quad, etc.
up,x,triangle,x,triangle,x,square,R2,right all taxis get nitro + jump up when you press L3
x,x,square,r1,l1,x,down,left,x andrenaline mode
RIGHT, R2, UP, UP, R2, CIRCLE, SQUARE, R2, L1, RIGHT, DOWN, L1 Aggressive Drivers
R2, R2, R2, X, L2, L1, R2, L1, DOWN, X Recruits Anyone (w/Rockets)
Down, X, Right, Left, Right, R1, Right, Down, Up, Triangle Infinite health, still hurt from explosions, drowning, and falling.
square,square,R2,left,up,square,R2,X,X,X Improve Suspension
L1, Circle, Triangle, L1, L1, Square, L2, Up, Down, Left All Pedestrians Are Elvis
DOWN, SQUARE, X, LEFT, R1, R2, LEFT, DOWN, DOWN, L1, L1, L1 Hitman In all weapon
L1, R1, SQUARE, R1, LEFT, R2, R1, LEFT, SQUARE, DOWN, L1, L1 Inf Ammo
L2, RIGHT, L1, TRIANGLE, RIGHT, RIGHT, R1, L1, RIGHT, L1, L1, L1 Chaos mode
CIRCLE, TRIANGLE, TRIANGLE, UP, CIRCLE, R1, L2, UP, TRIANGLE, L1, L1, L1 Max Sex appeal
L2, RIGHT, L1, UP, X, L1, L2, R2, R1, L1, L1, L1 All Traffic is Junk Cars
L1, R1, TRIANGLE, DOWN, R2, X, L1, UP, L2, L2, L1, L1 Max Respect
LEFT, TRIANGLE, R1, L1, UP, SQUARE, TRIANGLE, DOWN, CIRCLE, L2, L1, L1 All Cars Nos
TRIANGLE, LEFT, SQUARE, R2, UP, L2, DOWN, L1, X, L1, L1, L1 Traffic is Country Vehicles
SQUARE, L2, X, R1, L2, L2, LEFT, R1, RIGHT, L1, L1, L1 Max All Vehicle stats (Driving, Flying Bike, Cycling)
X, L1, UP, SQUARE, DOWN, X, L2, TRIANGLE, DOWN, R1, L1, L1 Peds Attack (Guns)
R1, UP, LEFT, RIGHT, R2, UP, RIGHT, SQUARE, RIGHT, L2, L1, L1 Spawn Tanker
CIRCLE, X, L1, CIRCLE, CIRCLE, L1, CIRCLE, R1, R2, L2, L1, L1 Spawn Hunter
L2, DOWN, DOWN, LEFT, SQUARE, LEFT, R2, SQUARE, X, R1, L1, L1 Weather Cloudy
Left, Right, Right, Right, Left, X, Down, Up, Square, Right Gang members spawn much faster
X, Square, Down, X, Square, Up, R1, R1 Calls the nearest ped to get in your car or get on your bike. Only gives a confirmation message if you're in a vehicle and there's a ped nearby
Njrider1230
Jul 29, 2023 05:16 AM
snake99
Sep 30, 2015 07:31 PM
awer1968
Sep 8, 2015 11:02 AM
Haakon
Aug 24, 2015 01:54 PM
randymack
Aug 24, 2015 05:47 AM
