Sportsman 90 Question...
Old Feb 11, 2008 | 12:06 AM
Cronk's Avatar
Default Sportsman 90 Question...
I bought my 02 SP 90 used, didn't come with a battery. I put a new battery in it and I get nothing when I try starting it up using the electric starter. By nothing I mean nothing at all. It will kick start no problem. I measured 13.4v at the battery. I haven't had the time to investigate it much, but was wonder if any body knows the answer to this question... Besides the starter switch what is different electrically between kick starting and the electric starter that may cause my problem?
Thanks!
Old Feb 13, 2008 | 06:45 PM
stemcell700's Avatar
friend has an 02 , about every two years so far, he's had to have the STATOR replaced, maybe that's it?
Old Feb 14, 2008 | 11:08 PM
BuRep's Avatar
Not to sound too simple and you may be well aware of this, but you have to pull the brake handle in before it will start. I only tell you this because my son has one and went riding with some neighbors. It died and they towed him in and then hauled it back to the house. Not sure why they didn't kick start it, but I walked right out and pulled in the brake handle and it cranked right up. None of them tried to pull in the brake handle. It's probably not that simple, but I figured I'd throw that out there.
Old Feb 15, 2008 | 12:02 AM
Cronk's Avatar
Thanks,
I did try the brake. The guy who had it before me was kind of a duct tape and bubble gum fixer if you know what I mean. I'm not sure if there is some thing disconnected some place I haven't found. The is a connector that this not connected to any thing in the front end where most of the wires are.
Does anyone know how to disable the brake interlock?
Old Feb 15, 2008 | 12:41 PM
kpracer's Avatar
Check to see if you have power going to the starter relay with a test light while hitting the starter switch. If you don't could be the switch. If you do see if you have power going to the starter motor by checking the power wire going to it with a test light. If you don't probably the starter relay, if you do its the starter motor.
Old Feb 16, 2008 | 10:50 AM
Cronk's Avatar
Thanks, I will test that this weekend! Thanks for the help.
Jmuddin284
Jan 19, 2026 07:16 AM
cdstang
Aug 31, 2015 07:52 AM
79hugger
Aug 30, 2015 02:21 PM
dwhipper61
Aug 27, 2015 11:01 AM
QuadCity
Aug 13, 2015 12:58 PM
