clutch ajustment
Old Feb 17, 2008 | 09:11 PM
rhonda350's Avatar
Default clutch ajustment
i have a 06 350rancher i ajusted my clutch clutch today and it says in the manual that loosen the bolt and turn this screw thing counterclock wise untill u feel slight resistence and then turn clock wise 1/4 i did that and i went ride and when i would down shift some times to like 1st 2nd or 3rd when i pudh the lever down it dosent shift the lever goes down get dosent shift lift the lever back up then press down it shifts then i shift from 1st to nutral i press down on the lever in nutral and it goed down it dose not suppose to do that then i prees down it again to see if i would do it again but it dosent wat u think is wrong should i turn the screw another turn or wat
Old Feb 17, 2008 | 09:57 PM
hondabuster's Avatar
Did you do the clutch adjustment with a warm motor ( it should be).
Were you sure the screw didnt also turn when the nut was snugged up? Hold it in place with the screwdriver, while snugging the nut.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
