Help with kazuma 150 gearbox
Old Mar 17, 2008 | 06:28 AM
xr81966's Avatar
Default Help with kazuma 150 gearbox
HI there. I would love some help on how to remove complete gearbox. We replaced all the gears in the box as they were stripped (kids not waiting until stationary before selecting reverse) but hubby tried to remove a nylock nut inside the box which probably didnt need undoing. Problem is now the bolt just spins in the hole and the nut wont tighten. We are assuming that this nut and bolt helps to hold the 2 sides together as it now has a really bad oil leak. Have checked all gaskets and seals and can only guess this is the cause.
We cant work out how to remove the hole gearbox to replace the bolt! Please help.
Oh and if I could work out to to add a picture I would show exactly which nut and bolt im talking about, so if you have any info on that.....
Old Jan 25, 2021 | 09:51 AM
Matty726's Avatar
Default Falcon 150.
Did you get it off? I have same problem. Nylon nut and keeps turning
Old Jan 25, 2021 | 09:53 AM
Matty726's Avatar
Default Falcon gear box
Any answers to this? I am having the same problem. Nylon nut keeps turning. How do I get whole gear box off? Is there an manual somewhere?
Old Jan 26, 2021 | 04:52 AM
There should be a manual for it. I downloaded a manual for the Falcon110cc machines a while back, can't remember where from. Strange book, no wiring diagram but pictures of every bit of the loom and how they join together. Rest of it is similar, goes into great detail on some things, total gloss over about other, more vital information.
exmotocrosser
Aug 4, 2014 01:27 PM
dlguitarman
Sep 9, 2010 11:28 AM
02yamahablaster
Mar 20, 2009 04:35 AM
Hightower
Sep 1, 2004 11:55 PM
unclematt
Jul 10, 2001 12:14 PM
