Is this the idle adjustment?
Old Mar 28, 2008 | 10:43 AM
pinetag's Avatar
Default Is this the idle adjustment?
Since I'm new to this, I wanted some opinions on whether or not I'm looking at the right thing. Is this the idle adjustment on the carb for my 2000 Honda Recon?
Thanks in advance.
Old Mar 28, 2008 | 03:12 PM
Gimpster's Avatar
Air fuel adjustment screw is what you have indicated
Idle screw is on the other side of the carb from what is pictured.
The idle adjustment screw is inserted into the carb horizontialy. The air fuel on this model is vertically mounted.
The adjustment you have pictured fine tunes the idle fuel air mixture. If in case you have turned it, to set it correct, let the unit idle and warm up. Turn the screw in until the engine starts to stammer or slow down. Turn it back out, counting the turns, until the engine begins to stammer once again. Turn it back in half the turns you counted and the fuel air should be set correct.
----- Gregg -----
Old Mar 28, 2008 | 03:22 PM
pinetag's Avatar
ok, thanks so much for your help.
Divergent12
Aug 19, 2023 05:26 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
ghost civic
Jul 30, 2015 04:09 PM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
MNatv89
Jul 7, 2015 11:36 AM
