wolvy450 clutch ?
Old Mar 31, 2008 | 09:25 PM
2wolvies's Avatar
Default wolvy450 clutch ?
how hard is it to remove clutch sheave and do ineed any special tools i'm looking to send it to hauck to have it machined
Old Mar 31, 2008 | 09:47 PM
NakedShotgunGuy's Avatar
Any help would be great I'm looking to do the same thing
Old Apr 1, 2008 | 10:14 AM
thumper10s's Avatar
impact gun and a socket set , and allen wrench is all you need as far as i remember
Old Apr 1, 2008 | 05:06 PM
ss454's Avatar
You'll need an 8mm, a 10mm and either a 3/4 or 7/8 as well as a small allen wrench (forgot what size)and a phillips screwdriver. You'll also need a tie strap to hold the sheave in place while you turn the nut. I'd personally ask Hauck how much it costs for them to take the sheave apart, clean it and then regrease it and put it back together. A tub of the grease is like $18...
Old Apr 1, 2008 | 05:34 PM
thumper10s's Avatar
its quite a bit easier if you have an impact gun, and $18 for grease, i paid 6 and only used maybe 1/4 of the tub
Old Apr 9, 2008 | 08:21 PM
2wolvies's Avatar
how do i take get slack in the belt to get it off ?
Old Apr 9, 2008 | 09:14 PM
ss454's Avatar
You don't need to take the belt off. You need to get a ratchet strap and wrap the line around the sheave then hook it on the footpeg so that when you turn the sheave it bites down and holds it so you can loosen the nut.
Old Apr 10, 2008 | 07:44 PM
2wolvies's Avatar
got the sheave off now what parts do isend to hauck is it just the empty sheave if anybody had pictures of what goes that would be great i'm hoping to have it cleaned and off to hauck tomorrow
Old Apr 10, 2008 | 11:06 PM
Eimajz's Avatar
This is not exact, but a good representation of what you need to send off.
Take the rollers out.. clean the sheave and send just the primary sheave.
Old Apr 13, 2008 | 11:40 AM
2wolvies's Avatar
thanks i sent my sheave out friday to hauck can't wait to get it back and see for myself what all the buzz is about
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
