Removing stickers
Old Jan 18, 2001 | 09:35 AM
OneDollar's Avatar
Anyone got a good tip on easily removing those annoying factory warning stickers without damaging the plastic. What solvents are safe?
Old Jan 18, 2001 | 10:04 AM
TheQuadfather's Avatar
I found the best way is to heat it up with a hair dryer, peel it off, then remove the left over adhesive with paint thinner.
Old Jan 18, 2001 | 10:38 AM
scr500's Avatar
I found a hair dryer didn't work well.I used a heavy duty heat gun.Be careful(don't melt the plastic) and heat from the back when you can.It still took me 2 hours to get those tough boogers off.They came off in little pieces.Polaris doesn't want them to come off!!
Old Jan 18, 2001 | 10:46 AM
MagnumMudMan's Avatar
One
I concur with quadfather. I tried several things including sticker remover, brake cleaner, wd40, and brake fluid. Nothing worked as well as a hairdryer. Just warm the sticker up and gently peel the sticker off. I then use wd40 to remove the sticker adhesive left on the plastic.
Old Jan 18, 2001 | 10:59 AM
schreibershaun's Avatar
I agree with quadfather too! Hairdryer works the best the problem with the heat gun is you get the sticker too hot and they come off in little pieces. If you just warm them up (not to hot) they will peal right off all in one. Take it slow though if you peal too fast they just come off in pieces. It will take a good hour. Including clean up. I used some GM tar and road oil remover to take off the adhesive. Have Fun!!
Old Jan 18, 2001 | 11:02 AM
3sportsman's Avatar
You have to use a hair dryer and alot of time.It makes you mad you think the whole sticker is going to come off when you start peeling in all you get is little pieces of the sticker. Once your committed you have to finish because it looks like hell.
Old Jan 18, 2001 | 11:04 AM
WIscrambler's Avatar
Hey Guys~
What worked for me was a 2800 PSI pressure washer. Once the stream of water got under the sticker, they were history! Also my dad just acquired a hot water pressure washer, so now I'm just waiting for the weather to warm up so I can degrease my machine!
Old Jan 18, 2001 | 01:25 PM
OneDollar's Avatar
Thanks fellow riders.
I never would have thought of the hair dryer trick I'll try to tackle the job tonite. I'm leaving with the family at noon Friday for 3 days & 2 nites camping and riding at Crooms (Brooksville Fla.).
ride on!
Old Jan 19, 2001 | 08:26 AM
OneDollar's Avatar
Thanks again!
I took off 20 stickers last night (all three bikes) in just about an hour! The hair dryer worked best when used from behind.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
