eton 2003 thunder 90 problems
Old Apr 11, 2008 | 09:15 PM
sean_hering's Avatar
Default eton 2003 thunder 90 problems
i have a 2003 eton thunder 90 that is acting up it is very had to start but when i get it going it runs for a little and turns back off what can i do to stop this problem it also gets over heated very quickly
Old Apr 12, 2008 | 01:39 PM
LT80's Avatar
LT80 Expert
Welcome to the forums. [img]i/expressions/face-icon-small-smile.gif[/img]
2 stroke?
If so, do a compression test.
Old Apr 12, 2008 | 05:03 PM
has good compression
Old Apr 13, 2008 | 10:25 AM
LT80's Avatar
LT80 Expert
Hows the plug color? A jetting problem?
If compression is fine, it's fuel or electrical.
It sounds like a timing issue, but unless you've messed with that it should be fine. Maybe a bad CDI/coil. A ohm test can check that. Sorry I don't have the ohm specs.
Old Apr 15, 2008 | 11:52 AM
kpracer's Avatar
Sound like dirty carb and stopped up jets. Disassemble carb and clean. Make sure
main and pilot jets are not obstructed and you can see through them. E-ton makes a manual choke kit that makes starting a breeze and gets rid of pesky electric choke. I just installed one today on customers old Lightning 50 E-ton. If your not getting proper fuel delivery your engine will be lean and run hot.
Jmuddin284
Jan 19, 2026 07:16 AM
Ramman1
Jun 16, 2016 09:07 PM
Captjay
Jul 23, 2015 12:33 PM
95wolv
Jul 17, 2015 08:13 PM
Chocobamofo
Jul 10, 2015 07:46 PM
