2005 Rancher Clutch Adjustment
Old Apr 15, 2008 | 10:48 AM
rcrcrcguy's Avatar
Default 2005 Rancher Clutch Adjustment
I've read that to properly adjust the clutch on a stock 2005 Rancher, 5 speed manual, you need to loosen up the nut on the front of the engine, turn the slotted bolt all the way out COUNTERCLOCKWISE until snug and then turn it back in 1/4 turn. Finally, while keeping the slotted bolt in the same position, tighten up the nut.
Sounds simple but....
If I loosen the nut a little, the slotted bolt will come out a little (~1-2 turns). If I loosen the nut allot (couple of turns) the slotted bolt will come out allot more too.
What is the correct procedure for doing this?
The transmission goes into 1 fine, 2nd with some effort and if I'm driving under a load or at speed, 3rd-5th are hard to shift into. I can shift up through th gears at very low speeds without too much problem but this just does not seem right.
Any help anyone can offer is appreciated. Thanks.
Old Apr 15, 2008 | 11:49 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
How come nobody ever has an owner's manual????
With the engine cold, loosen the lock nut. (If you have a problem with the slotted screw moving while you work the nut...just hold it still with a screw driver.) Turn the slotted screw counterclockwise until you just feel slight resistance (absolutely not until it is "snug"...ok!). Then, back it out clockwise 1/4 turn, and tighten the nut. (Again if you have a problem with the screw moving while you tighten the nut, just hold it still with a screw driver.)
Old Apr 16, 2008 | 04:51 AM
rcrcrcguy's Avatar
Thanks. The Rancher was just bought used and did not come with the manual (I asked). I have a Clymer manual which refers to 'clutch adjustment' but I could not find any details on it. I'm still trying to track down a '05 owner's manual.
txpedsrt1
Feb 3, 2017 08:07 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
Scottma518
Jul 16, 2015 09:19 PM
tporath
Jul 11, 2015 12:31 PM
Shifts
Jul 3, 2015 07:59 AM
