honda 300 trx engine problem
Old Apr 30, 2008 | 04:13 PM
barrentine's Avatar
Default honda 300 trx engine problem
I am working on this atv for a friend.It would run on choke as soon as you took it off choke it would spit spudder and die.I thoroughly cleaned carb with no success,even put another carb on and same thing.I adjusted valves which was noisy.when I was adjusting the valves I noticed the cam lobes were worn down so I removed the rocker cover to find worn cam and rockers.someone had put the oil filter in backwards.the engine had good compression so I replaced the cam and rockers,changed oil and filter and it crank right up but with same symptoms ,only run on choke.should I go back to the carb.any suggestions appreciated.
David
Old Apr 30, 2008 | 04:20 PM
john deere8640 's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img]i had same problem with a 300 and it was the carb we soaked it in cleaner overnight flushed good next day and rebuilt and it woys fine that was 2 yrs ago
Old May 1, 2008 | 12:22 PM
barrentine's Avatar
I took carb apart and the iow speed jet was stopped up.runs good now.thanks
Old May 1, 2008 | 05:36 PM
glad to be able to help you have a good day frank giles
neilbedwell
Nov 10, 2018 11:02 AM
Land_shark1
Jul 10, 2015 12:53 AM
hugemoth
Jun 4, 2015 02:56 AM
blaze_master
May 26, 2015 11:18 AM
lovinhonda
Jan 25, 2000 09:17 PM
