LT80 questions
Old May 1, 2008 | 03:05 AM
aqharoper's Avatar
Default LT80 questions
Can someone tell me the model number of the uni filter that most people use on the carb vent. Also has anyone used an inline gas filter if so what type and how does it work. Any opinions on a new petcock valve?
Old May 1, 2008 | 06:29 PM
Hymis's Avatar
Hello, I'll check my uni filter tonight. I have an inline filter, all you do is cut about 1 inch of the tubing and plug it in. You can get them from any motorcycle supply center for about 3.00-6.00 dollars. There is an arrow on the filter so you know which way the fuel flows. Why do you want to change out the petcock??
Old May 2, 2008 | 02:40 AM
aqharoper's Avatar
Hi Hymis,
I would like to be able to turn off the fuel flow completely. Have you know anyone to change them out? Someone suggested a banshee petcock.
Old May 2, 2008 | 04:37 PM
Rudedog's Avatar
Yes a Banshee Petcock will bolt right up. I beleive a BLaster petcock will also work as well... As these petcocks only have one (hose) outlet, you'll need to plug off the vent on the stock carb where the second hose typically goes from the stock petcock.
Rude Dog
Old May 4, 2008 | 02:29 PM
onebigzj's Avatar
spend that 40.00 or go to a lawnmower shop and get a in line filter and a inline gas shut off for 10.00. your choice
Old May 5, 2008 | 12:09 PM
aqharoper's Avatar
Thanks for all the suggestions. I am now looking for an inline filter from a mower dealer. I am going to try this first to see how it works before I change the petcock valve.
Old May 6, 2008 | 09:19 AM
LT80's Avatar
LT80 Expert
I see em at autozone.
shimanok2
Jan 29, 2016 07:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
2many2ride
Sep 27, 2015 04:35 AM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
