Bought 2005 blaster dirt cheap wont run can someone give me some advice??
Old May 11, 2008 | 04:35 PM
generichero's Avatar
Default Bought 2005 blaster dirt cheap wont run can someone give me some advice??
I bought a 2005 blaster. I know it used to run awesome because i bought it off a buddy. Problem is that it refuses to start. It is not spark because i am getting plenty. Its not compression either. What he did was drove it into a mud whole and REVed it to no end i guess. But it seems like the cylinder is fine. When i kick it it will not turn over. If i push start it n dump the clutch it will try to turn over and sputter but will die. Could it possibly be the clutch? is anything else on the bike prone to breaking down? please help me. If u need to know more to help me please email me generichero@rome.com also if you know any good websites to buy replacement parts please send me them too
thank you
zac
Old May 11, 2008 | 07:04 PM
mdebuck's Avatar
possible hydro lock, i'd suggest taking the exhaust pipe off, putting the bike on its front end and then try and move the kick starter. if water or anythig else besides gas comes out then that was your problem. if not then put your exhaust back on. if it was the clutch then you would feel the bike move forward everytiem you kicked it. even if the clutch was completly gone it would still try and kick over beings if there was no clutch then it would be just like neutral. hope this helps
Old May 16, 2008 | 01:54 AM
mpw8679's Avatar
Possibly water in the gas or carb. Try fresh gas and drain the carb bowl.
Old May 16, 2008 | 11:37 AM
shea_davis1214's Avatar
change you plugs too.............shea..........
neilbedwell
Nov 10, 2018 11:02 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Stillonit
Jun 18, 2015 11:23 AM
blaze_master
May 26, 2015 11:18 AM
