500 HO -wet belt
Old May 28, 2008 | 04:59 PM
snowmann's Avatar
Default 500 HO -wet belt
Does anyone know where the water would be getting into my PVT housing....Was using it as a submarine and when i came out of it the belt wouldn't catch in high gear...would catch enough to move in low....HELP!!!
Old May 28, 2008 | 05:03 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
3 ways. thru the air vent up by the gas tank. bypassing the clutch cover gasket or by the rear seal behind the clutch cover. if you were over your seat then it came in from the clutch vent.
Old May 28, 2008 | 07:28 PM
miniexcavator's Avatar
could also come in from your rope start if not seated well
Old May 28, 2008 | 08:55 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
How "DEEP" were you?
...............................Caper.............. ...
Old May 28, 2008 | 09:08 PM
snowmann's Avatar
seat was nearly submerged...
Old May 28, 2008 | 09:44 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you take off the left side panel you'll see the inlet to the clutch housing so if you were in water that high you better either bye a boat or plan on snorkling it.
Old May 29, 2008 | 12:04 AM
Deej's Avatar
Agree, it came in that really big hole called the belt housing vent!!
The guys here who want to run deeper water, put a snorkel kit on their machines (purchased or home made). The kit extends all vents, including the belt housing vent, much higher than the factory setup.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
