96 warrior carb
Old Jun 9, 2008 | 04:35 PM
giddle's Avatar
Default 96 warrior carb
i have a 97 warrior carb that will leak gas when its not running out the overflow even if i take the bowl off the carb and close the floats it will still seep out the overflow i thought the rubber o ring on the one jet was bad and its good there is no dirt nothing in the carb its a moose rebuild kit in it and im running a cobra pipe on it got any ideas
Old Jun 10, 2008 | 02:23 AM
91Warrior357's Avatar
bad float needle valve? or hmm how does it run?
Old Jun 10, 2008 | 04:03 PM
giddle's Avatar
once i get a tow and get it started it has no throttle response for about 1 or 2 seconds like its either loading on gas or sucking air i checked the carb boot even bent and twisted it to see if it has cracks and its good i know the floats are good cause i pulled them off of my 91 carb i referenced the part number and they was the same because originally the pump "rod" that goes from the top of the carb to the bowl broke and the 91 never had any carb problems But the 91 warrior was bored 20 over and to my knowledge the 96 is stock except for the cobra pipe on it
when i first changed the stator cause the pulse coil was bad it fired up for a couple seconds and shut off and now it has to be pull started to fire
i know its not good but i even put some starting fluid in the airbox and no go pulled the plug a lil spray in the cylinder no dice
its acting like somehow its out of time but to explain it running gas out of the over flow even when its off has nothing to do with the timing so any help u can offer would be greatly appreciated
Old Jun 10, 2008 | 04:10 PM
yea thats the accelerator pump plunger...hmm does it move freely? and does it have the spring on it that goes down into thew bowl, along with the rubber boot that covers the top of it? you can pull the black cover off to see the boot and see if it moves freely
Old Jun 10, 2008 | 06:03 PM
2Owanage's Avatar
are you sure its the over flow and comming from the hose at the bottom of the bowl?
Old Jun 10, 2008 | 11:10 PM
giddle's Avatar
the pump moves freely and yea the gas goes straight out the bowl just like if id crack the screw if there was air in the lines
i always though if i was getting more gas than i was supossed to it would make the quad run hotter
Old Jun 11, 2008 | 08:56 AM
SRVstrat's Avatar
do you have the float in up side down?
Old Jun 11, 2008 | 12:33 PM
lol
Old Jun 11, 2008 | 05:00 PM
giddle's Avatar
no its not upside down lol i dont know if the air screw got adjusted
Old Jun 13, 2008 | 10:12 AM
pmcc37's Avatar
its your float needle, did you put a new one in it?
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Reactant
Jul 16, 2015 10:29 PM
