blaster automaticly revs
Old Jun 12, 2008 | 08:37 PM
xxxalpinexxx80's Avatar
Default blaster automaticly revs
http://youtube.com/watch?v=2BH35I9sJ-I
ok so i took out my carb and put it back in and now my slider wont come down enough, something is wrong with my tors, i got a video of it and the cable is loose where it enters the tors, but on the tors there is a idle adjustment screw and it does not tighten or loosen it or anyhting : / any help apreciated, i tried about everything, and im sure there are no leaks e.c.t
but 1 question? what would happen if u ran a 2 stroke without any oil for a small amount of time like 5 sec
Old Jun 13, 2008 | 02:47 AM
DS650ryder's Avatar
i used to have a banshee and i don't remember being able to turn that screw that much. . . . somethins messed up with your tors as for the oil thing 5 sec wont do anything crap to tell u the truth i accidentally ran my banshee for 20 min of drag racing on straight gas >.< still ran great for like 3 more years with no problems then i sold it and as far as i know its still a 99 and the motor still hasn't been touched sooooo i don't think 5 sec is gunna do anything.
Old Jun 14, 2008 | 07:18 AM
hotblooded's Avatar
Just make sure that the needle isn't holding it up or the notch on the side of the slide is lined up correctly.
Old Jun 14, 2008 | 05:17 PM
i hooked up the oil line and it still reved, and i gues my tors (slider adjuster) is stripped, but what are other reasons to see why it can be reving i do have some pics of where my sider is positioned at if that will help at all
Old Jul 1, 2008 | 03:35 AM
rayblaster17's Avatar
what are the tors? i seen on a couple peoples signature on another website that they have them removed what does that do ????
Old Jul 1, 2008 | 04:46 AM
hotblooded's Avatar
The tors is only a kill switch in case of throttle stickage. Everyone that I know has them disconnected and taped off. You still need the block on top because that is the only idle control on those Mikunies. I would still bet that the slide isn't all the way in or the notch on the side of the slide isn't line up and letting it down. Now if you did other work to the motor like new gaskets or reeds it is possible that it is sucking air through a bad gasket. One way you can tell this is while it is running spray some chain lube around the area where the gasket is and if the motor changes rpms or sounds different then that is your problem. Let me know if this helps at all.
Old Jul 1, 2008 | 04:57 AM
gotcha
and i had that problem when i put my carb back together i didnt line up the slide right and there was was to much slack in the throttle cable but i caught it before i started it up
Old Jul 4, 2008 | 12:44 AM
mike828's Avatar
i have a 04 blaster and had a problem a little like u r having. the adjustment on top of the tors was not lined up on the inside. so i took the tors apart and the ajustment screw was not on the nidle. i just disconnected it and it runs alot better now
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Jaymc
Sep 11, 2015 07:45 AM
