06 500 Sportsman
Old Jul 15, 2008 | 01:40 AM
Polaris500Sportsman's Avatar
Default 06 500 Sportsman
Can anyone tell me what that easiest way to replace the brake pads are on the 06' Sportsman is? Thanks
Old Jul 15, 2008 | 08:32 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
once you take the wheel off you'll see its prety easy to do. i would get the ebc brand pads as they are better then stock for sure.
Old Jul 15, 2008 | 08:33 AM
atv gooroo's Avatar
Easy job! Take wheels off; Take caliper off(two bolts on back of strut); use an allen wrench to back out the set screw on the top side of the caliper;(look around the caliper it is the only allen head); pads should fall out; take a pry bar or big swrew driver and push the big piston on the caliper back in(big round circle in the middle of the caliper); put on the new pads; tighten the allen head set screw; slip back on disc; replace the two bolts; replace wheels; bleed brake lines if you like.
(Don't use lock tight on nothing. Also you might have to open the bleeder valve to push the piston back but try to do it with out opening the bleeder first.)
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
