oil temp sensor
Old Jul 16, 2008 | 10:01 PM
tigercubii's Avatar
Default oil temp sensor
I have a 1986 TRX 350 and the cooling fan never comes on. What is the troubleshooting procedure for the oil sensor?
Old Jul 17, 2008 | 07:07 AM
HondaMechanic's Avatar
If you unplug the oil temp sensor wires and short them together the oil light & fan should start ..
Old Jul 17, 2008 | 09:08 AM
tigercubii's Avatar
Thanks again Honda Mech,
I'll check it out next time I go north.
BTW I used your wiring diagram and traced out the Neutral/reverse connections and found the previous owner had jumped them out. I cleaned and pinched the connections, and put them back the way they should be, and both indicator lights work as they should! I suspect the guy jumped out the neutral switch to get the starter to work when it really only needed to be cleaned up. I don't know why he jumped the reverse switch AND the oil sensor, perhaps he didn't really have a plan and just jumped things out until it started....
Thanks again for your help.
Jeff Roper
Feb 1, 2022 11:48 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jeff Roper
Sep 21, 2015 02:11 PM
