oil temp sensor
Thanks again Honda Mech,
I'll check it out next time I go north.
BTW I used your wiring diagram and traced out the Neutral/reverse connections and found the previous owner had jumped them out. I cleaned and pinched the connections, and put them back the way they should be, and both indicator lights work as they should! I suspect the guy jumped out the neutral switch to get the starter to work when it really only needed to be cleaned up. I don't know why he jumped the reverse switch AND the oil sensor, perhaps he didn't really have a plan and just jumped things out until it started....
Thanks again for your help.
Jeff Roper
Feb 1, 2022 11:48 AM
jrooker6
Apr 23, 2016 07:36 PM
