Engine Popping
Old Jul 23, 2008 | 04:09 PM
Magnum95's Avatar
Default Engine Popping
Ive got a 95 Magnum 425 that backfires when you release the throttle after holding it steady for a bit. If you gently feather it to slowly reduce engine speed it seems okay. It seems to load the cylinder with fuel. Any suggestions?
I just bought this and otherwise its a great ride
Jeff
Old Jul 23, 2008 | 07:38 PM
cchucky51's Avatar
just a thought but try to remove bk wire form rev limiter that box can really play all kinds of troble
Old Jul 23, 2008 | 07:44 PM
<div class="FTQUOTE"><begin quote>Originally posted by: Magnum95
Also check throttle cable play,too muck slack can also cause backfiring. 1/16-1/8" slack
Jeff</end quote></div>
Old Jul 24, 2008 | 10:43 AM
Magnum95's Avatar
Thanks Guys
It seems hard starting at times. Almost like it floods. Perhaps the floats or needle is sticking
Old Jul 24, 2008 | 06:20 PM
Stout's Avatar
Was the oil changed the way it should be before you bought it? If not, the cam may be going out of it. Look at your oil and see if it smells like gas, if so, it could be the cam.
Old Jul 25, 2008 | 02:12 AM
CaptainQuint's Avatar
vibration sometimes causes problems with the needle or seat in the carb. Search the forum and there is some good info about the issue. I've also seen the carb itself crack and cause issues which mimic a bad cam. If you pull it to check the internals make sure to closely inspect the body of the carb itself.
Old Jul 25, 2008 | 11:00 AM
Magnum95's Avatar
Thanks guys
Will do
Old Jul 27, 2008 | 12:56 AM
Kerbbirds's Avatar
could it just be running lean, check and see what ur spark plug looks like as far a color, it it's white, it's lean, if it's black, it's rich. i'd check that before goin to far into it
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
ghost civic
Jul 30, 2015 04:09 PM
cornermike
Jul 30, 2015 06:37 AM
ghost civic
Jul 19, 2015 10:13 AM
