Shocks needed for an '86 200sx
Old Aug 17, 2008 | 12:29 AM
trogg's Avatar
Default Shocks needed for an '86 200sx
a few quick questions
What shocks will work up front?
I was told a later 2005ish 250ex rear will fit nicely true/not true?
Is there an aftermarket pipe and silencer for it?
also looking for bumpers/stuff
please help
Old Aug 18, 2008 | 11:45 AM
ttaylor's Avatar
You are going to have a hard time getting information on a machine that old. Pretty much anything you do will most likely be trial and error especially trying to find a bumper or something.
I have a 2003 Recon 250ES which is the same as the 250EX. If you will post your shock lengths and the width of the shock at the eye I will measure mine and let you know if they match up. I would also look more along the lines of the 250X or 300EX sport quads and see if they match up. You will have a far greater chance at picking up spare parts off the true sport quads than you will the utilities or wanna-be sport quad.
Another item you might want to consider is back then the quads had smaller tires in the front and larger tires in the rear. Most quads today either run the same or slightly larger tire in the front because it makes the quad steer and turn better.
Old Aug 19, 2008 | 01:26 AM
trogg's Avatar
good thinking, and thanks for looking out! i showed some interest on ebay in some 300ex shocks and im going to take the old one off and post some dimensions and stud sizes, (the bolt that holds it in)
also have a background with welding so if necessary i could move shocks etc.
Old Aug 19, 2008 | 01:37 PM
ttaylor's Avatar
300EX shocks are 13" eye to eye if I remember correctly. A lot of racers who ran the 300EX switched to 250R shocks and bought a conversion kit that allowed them to run the longer shocks. The conversion kit moved the upper mounting bracket up 2". This may give you more options. too.
God Luck
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
sara durrant
Jul 6, 2015 05:32 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
