Polaris (eton) 90 dies in water
Old Aug 25, 2008 | 11:41 AM
MD80 Driver's Avatar
Default Polaris (eton) 90 dies in water
Long time listener, first time caller...
I have an 07 & 08 Polaris 90. the 08 works perfectly. The 07 occasionally dies or runs rough when my son goes through water. Nothing to deep (below running boards). After a while the machine will finally run after a little throttle feathering to keep it going. Any thoughts? The air box in dry so could it be electrical?
Old Aug 25, 2008 | 02:38 PM
rjdad's Avatar
I think you are right, it does sound like an electrical problem, have you used dielectric grease on all of your connectors? I would also try and waterproof everything up to the carb. I asked about relocating the snorkel to the air box and was told that it would not decrease the performance of the engine. My son likes the water as well and it seemed to have worked for me. Hope my 2 cents helped.
Old Aug 25, 2008 | 03:07 PM
The airbox stays dry so I tend to agree it is electrical. I also have an issue with the throttle, when my son mashes the throttle on the 07 it will die. So I thought my whole problem was carburation but this week it died the instant he went through water. I'm going to pull the carb and have it dipped then use electrical grease on all electrical connections and see if this solves the problem. It is frustrating that the 07 is having problems and the 08 runs perfectly! Thanks for the $$!
Old Aug 27, 2008 | 04:33 AM
hotblooded's Avatar
This sounds kinda crazy but all I had was a can of black spray paint, I painted all the connections and let them dry. It seemed to waterproof it some.One other problem we had was water getting in the stator.
Old Aug 27, 2008 | 07:56 PM
Thanks for all the input. I spent the morning using dielectric grease on every electrical part. The machine runs great now so we will see how it does in the water!!!
Old Aug 28, 2008 | 02:40 PM
rjdad's Avatar
Make sure that the portion of the airbox that attaches to the carb is sealed as well.
Old Aug 28, 2008 | 06:31 PM
Thanks for the tip. I went back today to reseal those connections as well. Can't wait to see if that corrected the problem.
Old Aug 28, 2008 | 06:54 PM
rjdad's Avatar
I hope so, there is nothing that is more pleasing than to see kids having a good time in my book.
Jmuddin284
Jan 19, 2026 07:16 AM
Ramman1
Jun 16, 2016 09:07 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 4, 2015 06:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
