different carb for warrior?
Old Sep 1, 2008 | 11:46 AM
MXmadness577's Avatar
Default different carb for warrior?
ok guys i might be making a stroker warrior to bs with my buddies z400 and kfx450 if i can even keep close to it but anyway i figure if im gonna bore and stroke it its gonna need to breathe anyone know of a bigger carb for it from another stock quad or something? i dont realy want to spend like$500 on a aftermarket one any1 else whos built a stroker warrior could possibly give me some tips?
Old Sep 1, 2008 | 12:13 PM
Raptor450's Avatar
My buddy had a Warrior with the old 500 cc stroker that you can't get anymore, and he was running a 400EX carb that worked pretty good. I had the stock carb on mine that had the 446 stroker from FST and it worked good. They say the Edelbrock carbs are the carb to have on the Warrior, but at $300-400 they should be! The main problem with switching carbs to one that isn't designed for a Warrior is your airbox may have to be modified to fit the new carb. This can sometimes be a small headache.
Old Sep 1, 2008 | 12:48 PM
ok thanks for the info did u like the kit from FST? did it cause any problems and could u send me a link for it. and whats the difference in stroke like 7mm and 9mm and what not i dont understand what the different lengths do
Old Sep 1, 2008 | 02:36 PM
Raptor450's Avatar
The FST 446 was alright, but it didn't impress me any. Maybe I was expecting too much. It wasn't worth what it cost - about $1500 total. I could have sold my Warrior, put the $1500 with the money from the Warrior, and bought a Raptor 660 and been faster with the stock engine. The longer stroke means the connecting rod that connects the piston to the crank is longer, which means the piston travels further up and down in the cylinder, which gives you more compression and more power. Anytime you modify something, you lose some reliability, so the best thing to do is keep the engine as reliable as possible for trail riding, which does not mean putting a stroker in it. The stroker creates so much pressure, I had problems with mine blowing out the head gasket. My buddies with the 500 cc had oil leaking out of every gasket on the engine where the pressure just pushed the oil out. He also had trouble with his crankcase gasket leaking oil and had to replace it several times, so really it's more headache than it's worth and not as reliable as other mods.
Old Sep 1, 2008 | 03:26 PM
91Warrior357's Avatar
using a z400 carb is another good choice, i think you gotta use the raptor 350 intake boot and then use the z400 carb with the cable and throttle, and after dialing it in they work really good.im still debating on whether to get an edelbrock for my warrior but i might sell my warrior and get a 400ex or a predator. the way my warrior runs now it keeps up with stock 400's but it wont get much faster without putting to much money into it and it wont be worth it.
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Reactant
Jul 16, 2015 10:29 PM
