drive chain
Old Sep 30, 2008 | 04:58 PM
beercase's Avatar
Default drive chain
I have just replaced the front 14t sprocket with a 12t sprocket for a 420 chain but no matter how I adjust the tension now there always seems to be a spot that the chain does not mesh...do I need to remove links or does anyone have any suggestions...
thanks
Old Sep 30, 2008 | 05:11 PM
LT80's Avatar
LT80 Expert
Default drive chain
1st off, is it 520 or 428 chain/sprocket size ??? Both those numbers seem to get mixxed and matched sometimes. [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
If 428::::Go to a tractor supply, MSCDirect.com, or a go-kart shop and get #40 chain. It comes in 10 ft lengths (and yes, it fits perfect). They will have the master links and the all important 1/2 links that your needing.
I can get all that for under 20 bucks at the tractor supply.
If 520:: a tooth bigger/smaller rear sprocket. I know of no 520 1/2 links. maybe someone else can help more. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 30, 2008 | 06:20 PM
beercase's Avatar
Default drive chain
sorry it is a 420 sprocket and a 420 chain...
Old Sep 30, 2008 | 07:21 PM
luvmysxs's Avatar
Default drive chain
what you need to do is loosen up the rear axle and the chain adjusters, push the axle all the way forward, remove the master link and then reinstall the chain on the spockets, and see if you have a extra inner and outer link, you must beable to remove both, so that their's a inner link on each side of the chain. if you do then simply take a chain breaker and remove them. reinstall chain.
Old Oct 1, 2008 | 05:35 PM
beercase's Avatar
Default drive chain
I found out that it was the gold locking key was a hair too long and was knocking the chain off the sprocket...are there different sizes of these or should I grind a hair off to make it fit inside the chain??
Old Oct 1, 2008 | 05:57 PM
luvmysxs's Avatar
Default drive chain
you need to grind the spocket retainer to clear the chain and you also need to change the bolts to allen heads bolts, otherwise the bolt heads will also ride on the chain,
Old Oct 2, 2008 | 11:28 AM
beercase's Avatar
Default drive chain
thanks that worked out great
frostphase
Aug 23, 2015 07:36 PM
firsttimerider
3) General Discussions..
8
Aug 21, 2015 08:55 PM
DeFox500
Aug 14, 2015 05:59 PM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
