belt rubbing
Old Oct 7, 2008 | 04:42 PM
trybaj17's Avatar
Default belt rubbing
Back in spring I ordered a stage 1 kit from RCR and I love it but I hear the belt rubbing on the cover a little bit when I let off the throttle after a wide open run. Rick sent me a black and white primary and a polaris purple secondary. Could the primary be to stiff or the secondary?
Old Oct 7, 2008 | 09:49 PM
Could just be belt flex off of full throttle slapping cover. Try in neutral,gas it,let off see if belt slaps cover? Could be spring set up or a little belt stretch.
Old Oct 7, 2008 | 09:55 PM
trybaj17's Avatar
On the secondary i have it at the tightest setting. Ill give that a try because i am goin home tomarrow and going ridding this weekend.
Old Oct 9, 2008 | 03:56 PM
trybaj17's Avatar
i just reved up the motor in neutral and the belt did rub on the clutch cover, so it does rub in gear and in neutral.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
