2003 Prairie 650
Old Oct 7, 2008 | 09:12 PM
mxz71's Avatar
Default 2003 Prairie 650
What would an 03 Prairie 650 with approx. 400mi. be worth. I was offered a trade for my jet skis and cant find much info on this model. Thanks
Old Oct 7, 2008 | 09:45 PM
ATV24/7's Avatar
The NADA is $2700-3500.
Old Oct 8, 2008 | 01:39 PM
Hayashi's Avatar
When checking out a P650, look for possible problems following area:
> CVT
> Engine Top End
> 2/4WD engagement
> EBC
> Anything flashing on dash meter.
Old Oct 14, 2008 | 08:38 PM
mxz71's Avatar
Does anyone else know of any common or not so common issue with this model? I got pics of it and the odometer shows 505 miles and it looks clean. Physically it dont look as big as my 05 Cat 650H1.. I am planning on going to look at it this weekend so I'd like to be at least a little bit educated. Thanks
Old Oct 17, 2008 | 02:16 AM
MikeyBoyesq's Avatar
If it has or ever had large mud tires, be sure to check for play in the front steering...sometimes the big mud tires will lead to worn out tie rod ends or wobbling out the holes in the bottom of the steering stem.
Also, check for leaks coming from the engine and front diff oil seals...this is common problem on the Prairies, but usually cheap to fix if you do it yourself.
505 miles is very low mileage for a 2003 Prairie...its probably in good shape as long as it wasn't used as a mud machine! I bought a 2002 P650 once for dirt cheap and it had very low miles...I later found out why it was so cheap...some parts (steering components) were worn out from the deep mudding using oversized mud tires.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
ReconBayou
Oct 16, 2019 02:24 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
Hw00d
Sep 10, 2015 08:53 AM
