96 yfm no sprk when hot
Old Oct 12, 2008 | 11:01 PM
taylorteamracing's Avatar
Default 96 yfm no sprk when hot
i have a 96 warrior and it does not start when hot i checked the fuse at the back of the atv and changed plugs i put it on the trailer took it home and it fired right up by the time i drove it off the trailer and up the driveway it shut off again and wouldnt re start oil level is good ?????????????? i have no idea
Old Oct 12, 2008 | 11:09 PM
Raptor450's Avatar
Dang!!!! What's up with all these Warriors having electrical issues??? I would check the stator first, then the ignition coil, then the CDI, but you have the symptoms of a bad stator. You need an ohm meter and the specs from a manual as to what the ohms should read. You can download a free manual from sandwizards.com/tips&tricks
Old Oct 12, 2008 | 11:13 PM
yea i was reading the post and was wondering the same thing one of the other post said it should be between 180 and 220 ohms
schepp
Dec 7, 2013 12:04 AM
punkkinen87
Mar 26, 2009 02:45 PM
TimberedWolf250
ATC 3-Wheelers
Jul 3, 2008 03:41 PM
HFD84
Jul 1, 2008 11:38 PM
acesbimmers
Jul 2, 2006 05:09 PM
