Polaric Sportman 500 ho help
have a polaris 500 Sportsman ho, will not start
ran great , started great no problems. Now suddenly will not start.
will crank but will not start. Have fresh gas in tank, Have a good spark, Have a good flow of gas to carb. , Have replaced the sprk plug.
Any suggestions
Any suggestions
Does it start with the pull rope?
Mine had a hard time starting , turned out dirty water made its way down the pull rope hole into the recoil and made the pulse coil dirty/rusty. I cleaned the pulse coil's magnetic face up and it started up great after that.
I siliconed the pull rope handle over the rope hole so water will not get in again.
